Reply
R6300 V1 ReadyShare printer function not working
old1mike
Windows 10 V1903 build 18362.476
ReadyShare USB control center V1.36 driver 1.83.35
R6300 V1 Firmware Version V1.0.2.80_1.0.59
This setup was working fine less than a week ago. I know Microsoft put out win10 update resently. Now ReadyShare print/usb function not working. I am positive it is a driver issue. After update I now have an 'unknown device' in device manager. I have 3 other windows 10  pc's. All are having same issue. My laptop (Windows 10) device manager has a 'Broadcom USH' with bad driver. Uninstalled/reinstalled readyshare downloaded from 'http://www.downloads.netgear.com/files/GDC/R6300/ReadySharePrinter_setup_v1.36.zip'. Still same issue. Tried power off/on router. Same issue. Reboot computers. Same issue. Since my router is over the 90days and I could not find anywhere in 'support' for software issue I am posting this here hoping someone from Netgear can advise the appropriate people, or someone here knows how to get a good working driver.
Thanks
Mike
Model: R6300|Dual Band 11ac WiFi Router R6300
Message 1 of 2
schumaku
Guru
Re: R6300 V1 ReadyShare printer function not working
USH stands for Unified Security Hub - the Broadcom USH is mainly used for the fingerprint reader, it can be in place even if you don't have a fingerprint reader on your computer.
Head to the computer vendor support/download site, Dell for example had it listed as "Security Manager" - carefully choose 32 bit or 64 bit, depending on your WIndows installation.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 361 views
  • 0 kudos
  • 2 in conversation
Announcements
