× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
R6300 getting 100/100 but I have gigabit connection
fleeper
Initiate
I have an R6300 and I have a gigabit connection. If I bypass the router I get a very fast speed but if I connect via Ethernet through the router I am getting 100mb up and down. What do I need to do to get gigabit out of the router?
Message 1 of 3
Accepted Solutions
TheEther
Guru
Re: R6300 getting 100/100 but I have gigabit connection
Make sure your Ethernet cables are Cat5e or better. In addition, Gigabit Ethernet uses all 8 wires in the cable. If even 1 wire is damaged, the interface will drop down to 100 Mbps, which only uses 4 wires.
Message 2 of 3
All Replies
TheEther
Guru
Message 2 of 3
fleeper
Initiate
That was it.  I changed to a new cable and it worked!  Thanks much for the suggestion.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2761 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
