× Some paid Circle Parental controls customers may be showing free options only. Router firmware correcting this issue will be available ASAP. Visit Status.NETGEAR.com for updates.
Discussion stats
  • 14 replies
  • 3428 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
R6300 not detecting Ethernet connection
model:  R6300
Suddenly the ethernet stopped on unit. I have tried 2 different ethernet cables, both good, and I have tried plugging in to every port on the back with no response. I have reset the router, my modem, checked every troubleshoot I can find. No luck. Please help.
Model: R6300|Dual Band 11ac WiFi Router R6300
Message 1 of 15
Accepted Solutions
Highlighted
NETGEAR Moderator
Re: R6300 not detecting Ethernet connection
Hi @pgilliam,
1. Please try performing a loop back test to check if the ports still work. You can check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/28408
Note: you can check the Internet light for the model of your router.
2. If the loop back test shows that the ports still work, please check if the connected device on one/any of the LAN ports still get a valid IP address.
3. If it still does get a valid IP, you can try re-flashing the firmware of the router then reset and reconfigure it. You can check the links below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
Message 2 of 15
All Replies
Highlighted
NETGEAR Moderator
Hi @pgilliam,
Dexter
Community Team
Message 2 of 15
Highlighted
NETGEAR Moderator
Hi @pgilliam,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 15
Highlighted
For some reason, I have to reset my router alot!
Message 4 of 15
Highlighted
NETGEAR Moderator
Hi @pgilliam,
1. Does the Ethernet connection still continue to drop?
2. If you have not done it yet, you can re-flash the firmware of the router.
3. Did the loop back test come out okay?
Dexter
Community Team
Message 5 of 15
Highlighted
Every morning I am offline. The loop back instruction was successful. I can't figure out how to find an update. R6300v1 or v2? I find the support page is not very user friendly. Where do I find the re-flash option?
Message 6 of 15
Highlighted
NETGEAR Moderator
Hi @pgilliam,
If the loop back test showed that the ports work then you can try re-flashing the firmware of the router. First, make sure you know the correct version of the router as indicated on the label (has v2 for version 2, just R6300 for v1). You can check the links below on how to re-flash and reset the router.
Dexter
Community Team
Message 7 of 15
Highlighted
NETGEAR Moderator
Hi @pgilliam,
Dexter
Community Team
Message 8 of 15
Highlighted
Constantly have to reset wireless network adapter
Message 9 of 15
Highlighted
NETGEAR Moderator
Hi @pgilliam,
1. Is the Ethernet connection working fine now?
2. Is the issue with the wireless connectivity?
3. You can try changing the wireless channel.
Dexter
Community Team
Message 10 of 15
Highlighted
Wireless connectivity
How to change wireless channel?
ethernet from modem to router works fine
several times a day i have to reset my wireless adapter
Message 11 of 15
Highlighted
NETGEAR Moderator
Hi @pgilliam,
You can check the link below.
http://kb.netgear.com/app/answers/detail/a_id/24095
Dexter
Community Team
Message 12 of 15
Highlighted
NETGEAR Moderator
Hi @pgilliam,
Dexter
Community Team
Message 13 of 15
Highlighted
Yes I have to reset my network adapter at least twice a day
Message 14 of 15
Highlighted
NETGEAR Moderator
Hi @pgilliam,
I have sent you a message. Please check your inbox.
Dexter
Community Team
Message 15 of 15
