Reply
R6300 not working with CVSNT service
Yilin
Follower
I installed cvsnt which uses ports 2401, 2402. Set the router port forwarding as usual but it worked only for machine name, not associated domain name mydomain.net.
The router worked for filezilla(ftp), http(website) but not for cvs. Anyway to fixing?
Thanks
Model: R6300v1|Dual Band Gigabit Wireless Router - 802.11ac
Message 1 of 2
antinode
Guru
Re: R6300 not working with CVSNT service
> [...] Set the router port forwarding as usual [...]
   Not a very detailed description.  What are the actual port-forwarding
rules?  Copy+paste is your friend.
> [...] but it worked only for machine name, not associated domain name
> mydomain.net.
   Does that mean that you can access the CVSNT services from a system
on your LAN, using the server's LAN IP address, but not from the outside
world, using the router's WAN/Internet IP address?
> The router worked for filezilla(ftp), http(website) [...]
   "worked"?  Are those services still working?  Tested how, exactly?
   If some services work from the outside world, and some do not, then
my first guess would be bad port-forwarding rules.  I'd expect any other
likely problem to affect all services.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 291 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
