Reply
R6300v1 as a range extender?
aussiefella
Follower
Hi members,
I have a D6300 and an R6300v1.
I would like to use the R6300v1 as a range extender to extend the signal of the D6300 to a remote part of the house.
Can I use the R6300v1 as a range extender?
If so, how do I set up the R6300v1 as a range extender?
I will greatly appreciate any help with this issue.
Cheers
aussiefella
Message 1 of 2
jmizoguchi
Virtuoso
Re: R6300v1 as a range extender?
Plenty of these setup in the forum
You can only use WDS and it will 54Mbps/WEP or No security.
I would suggest to use ethernet cable at remote end or get extender such as ex. wn2500rp
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3543 views
  • 0 kudos
  • 2 in conversation
Announcements
