gasman90255
Dec 24, 2017Follower
R6300v2 - Firmware update error
Hello, when I try to update the firm ware I keep getting an error message after it tries to update. I tried connecting to the router directly with a network cable, via wifi, with different web browsers and two different computers with no luck. Attached is a picture showing the update info and another picture showing the error message. Thank you.
Hi gasman90255,
As suggested by nwilliam3, you can try manually updating the firmware. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/23960
http://kb.netgear.com/app/answers/detail/a_id/9665Regards,
Dexter
Community Team
- nwilliam3InitiateI had the same issue. Had to download the update directly from Netgear and then manually load it from the Administration page.
- DexterJBNETGEAR Moderator
Hi gasman90255,
Dexter
Community Team
