Reply
R6300v2 New Firmware V1.0.3.28_10.0.71
gahelm
Novice
In case you don't know it there is new firmware available for the 6300v2 in the Downloads section of this site. It didn't show up when I checked for it from the Router UI so be sure to download it and install it from a hard wired PC. (Not over wireless.)
It seems to be working fine for me.
Regards
Message 1 of 28
Babylon5
NETGEAR Employee Retired
Re: 6300v2 New Firmware V1.0.3.28_10.0.71
R6300v2 Firmware Version 1.0.3.28
New Features & Enhancements:
Improves the auto channel selection algorithm.
Bug Fixes:
Fixes security vulnerability issue.
____________________________
Working on behalf of Netgear
My name is Andy
Message 2 of 28
Flyhalf205
Novice
So I figured out why I couldn't flash the new firmware that I had when the previous firmware was released. My original router was a CH version. I had to flash dd-wrt.K3_R6300V2CH then upgrade to the newest firmware then restore settings.
Message 3 of 28
thatblastedhuma
Does this firmware fix NetUSB?
Message 4 of 28
Fairytail
Virtuoso
No information about the NetUSB. You may try to load the firmware and check if it works.
Message 5 of 28
thatblastedhuma
Why won't NetGear be more transparent? And tell us what vulnerability it fixes?
Message 6 of 28
Babylon5
The information is here;
http://kb.netgear.com/app/answers/detail/a_id/28393
My name is Andy
Message 7 of 28
ant
Virtuoso
Virtuoso
Regards
How come it is not showing up in router's web page UI? Smiley Sad
Message 8 of 28
MrHQ1
Just wanted to mention this firmware is working great for me. I updated from the Original firmware to this version.
Created a backup of my config & my router was down for maybe 2 minutes during the update. The entire process was flawless & very fast. I love it when a plan comes together.
Message 9 of 28
karthik02
Re: New firmwaare R6300v2-V1.0.3.6_1.0.63CH ?
After flashing the v1.0.3.28_10.0.71 firmware (after flashing the dd-wrt firmware on, of course), the router login page doesn't come up. It used to be a Charter router, so I can't reach out to Netgear for support. Any ideas?
Message 10 of 28
Babylon5
Did you factory reset the router after installing the Netgear firmware and re-enter settings manually, if not I suggest that you do so?
My name is Andy
Message 11 of 28
Flyhalf205
Novice
You will need to reset your router. I have the same problem as you. I have a Charter router.
Message 12 of 28
LGregory
Login Issues
Recently updated to the new firmware (V1.0.3.28_10.0.71) and it seems that now, unless I reset my router, after a little while I can't login to the router or access my usb HDD. After resetting the router and log in to it, the router displays a message that it is logged in from another device. I tell it to continue and it works fine for a bit afterwards. Doesn't seem to affect the internet connection. Just local network login/access. Can someone shed some light on what may be causing this or is it a bug?
Message 13 of 28
Babylon5
Save your current configuration to a file, then factory reset the router. Just enter the minimum settings necessary to get things working and see how that goes. If all works well then you could try reloading the saved configuration.
Could you list the types of devices you have on your LAN please?
My name is Andy
Message 14 of 28
LGregory
I usually have about 8 devices connected by WiFi and a couple direct wired. Smartphones, tablets, a printer, a couple of computers by WiFi, and a computer and a switch (which happens to have nothing plugged in to it right now) are direct wired. I'll let you know how the reset goes.
Message 15 of 28
S-Warren
Tutor
I have the 6220v2 and it doesn't find new firmware from the UI either. I had to check the Netgear site to even know there is a firmware upgrade for my unit. This suggests that there are issues in the UI of several different Netgear Wifi Router models.
Message 16 of 28
ElaineM
Hi @S-Warren,
Are you still unable to get the automatic firmware update on the router GUI? Can you confirm if it's still doing this until now?
Thanks!
ElaineM
NETGEAR Community Team
Message 17 of 28
S-Warren
Tutor
@ElaineM,
Yes I'm still unable to get firmware updates from the router GUI. When I click on Advanced, Administration, Firmware Update I get these messages:
Attempting to connect to Netgear Server 1
Attempting to connect to Netgear Server 2
Attempting to connect to Netgear Server 3
No new firmware version available
Judging from the above, it appears the GUI is not making a connection with the Netgear servers.
Message 18 of 28
ElaineM
@S-Warren Have you tried power cycling the router and see if it will do the same thing? How about router reset? What is the current firmware version of your router?
ElaineM
Message 19 of 28
S-Warren
Tutor
@ElaineM,
Yes I unplugged the router first and tried that, then did a factory reset none of which worked. My current version is V1.0.0.17_1.0.1.  Currently my bandwidth has slowed to a crawl, web pages taking a long time to load.  I don't know if this new issue is router related or with my ISP. I'll monitor things throughout the day to see if my bandwidth improves.
Message 20 of 28
ElaineM
@S-Warren Kindly try the 30-30-30 reset. After reset, reconfigure and see if you can use the auto update.
1. With the unit powered on, press and hold the reset button on the back of unit for 30seconds.
2. Without releasing the reset button, unplug the unit and hold reset for another 30 seconds.
3. Power on the unit while STILL pushing the reset button and count for another 30 seconds before letting it go.
ElaineM
Message 21 of 28
S-Warren
Tutor
@ElaineM,
Thanks for your replies and willingness to help ElainM. I ended up manually updating the firmware to v1.1.0.31 and all works great except the occasional need to power off/on the router to re-establish connections for my devices.
Message 22 of 28
ElaineM
@S-Warren Thank you for the update. Have you tried the reset procedure? You're trying to re-establishing connection on wired or wireless devices?
ElaineM
Message 23 of 28
S-Warren
Tutor
On wireless devices. Every now and then wireless devices lose connectivity with the router so I have taught my household to just power off the router then turn it back on which fixes eveything. It dosen't happen often that they need to do this so that's a good thing.
Message 24 of 28
ElaineM
@S-Warren If you have tried changing channels and making sure that there are no other wireless interference near the router. Try changing the Fragmentation Length and CTS/RTS Threshold to 2304. Reconnect your wireless devices and observe your connection.
ElaineM
Message 25 of 28
Top Contributors
Discussion stats
  • 27 replies
  • 17637 views
  • 2 kudos
  • 11 in conversation
Announcements
