Reply
R6400 Internet Coonection
kagy
Luminary
Not a techie, so understand I asking for a simple response. Internet thru Cox. Have Desktop (Dell), two 6s iphones and a couple of Ipad in play at any time. Today My desktop lost internet connection this morning and Cox had no outages and felt that it might be the router. Ipads had connection, then lost and then regained. My iphone along with Desktop lost connection for the longest period. Finally after visiting with Cox and trying the old "restart" process all device came back to life and connected. Question is there a simple way to test router to determine if that is the problem in this case or in any case?
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 2
antinode
Guru
Re: R6400 Internet Coonection
   Is that accurate?  Not R6400v2?  Look at the product label.  Firmware
version?  Connected to what?
> [...] Internet thru Cox. [...]
   You have some kind of modem?
> [...] is there a simple way to test router to determine if that is the
   Define "simple"?  Probably not without some useful information.
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Read.  Look for the
LED descriptions and "Troubleshoot".
   I assume that your (unmentioned) modem also has some LED indicators,
which might provide some information.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 313 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
