RynoRBO
Sep 26, 2022Follower
R6400 Wifi much slower
Why is my R6400 wifi much slower than advertised?
Both 2,4Ghz and 5Ghz are very low
Strangely enough 5Ghz is slower than 2,4Ghz, which does not make sense
There are other higher speed
Firmware is up to date R6400v1 V1.0.1.78_1.0.50
options
1 Reply
Those are possible connections rate speeds that maybe seen between the router and the connecting client devices over wifi. Connection rates depend on supported design by the Mfr. Consult the Mfrs support site for help and information regarding there products.
