Discussion stats
  • 3 replies
  • 4100 views
  • 0 kudos
  • 3 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
R6400 antennas
I just istalled a brand new R6400 AC1750 on my network. When I set it up one of the outer antennas just flops to the ground and won't stand at a 45 degree angle as recommended. Is there a way to tighten it, as it is not removable?
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 4
Highlighted
NETGEAR Moderator
Re: R6400 antennas
Hi @dlacki,
There is no mechanism for you to tighten the antenna/s to the device. If you just recently purchased it, we recommend having it replaced from where you purchased it.
Dexter
Community Team
Message 2 of 4
Highlighted
Re: R6400 antennas
I noticed that my right-side antenna is also flopping over and seems loose at the connection point.
There doesn't seem to be a way to "tighten" it.
Is this also a hardware warranty issue as the unit was purchase at end of July, 2016?
Thanks,
Herb...
ReadyNAS RN516
ReadyNAS RN214
ReadyNAS RN102
ReadyNAS NV+
ReadyNAS Pro Business Edition RNDP6350
Netgear R6400
Message 3 of 4
Highlighted
NETGEAR Moderator
Re: R6400 antennas
Hi @herbg,
We recommend contacting support to check for the hardware warranty coverage of your device.
Dexter
Community Team
Message 4 of 4
