Reply
R6400v2 admin login not accepted
GaryDM
The Nighthawk app & website login page will not accept my admin password so I did the password recovery to assure I was using the correct password - which I was. It still wouldn't work so I did a reset & I still can't log in with the factory default password.
Message 1 of 5
Guru
Re: R6400v2 admin login not accepted
When many do "the reset" they don't end up holding reset long enough.
With the router fully powered on, push and hold reset for 7-10 seconds or until the lights change. Some devices it can be up to 30 seconds.
Another thing to try is a different computer. If you have an autofill for passwords, many times this will overwrite your existing password you're entering. If you try a different computer or potentially different browser, sometimes this will work.
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 5
GaryDM
The button was held in until all LEDs blanked out. I was careful to not mouse-over the autofill so what I was typing was what was entered & I attempted  logging in on the website & through the Nighthawk phone app.
Interestingly, after doing the reset twice, password recovery was still showing my old password & not the factory reset password.
Message 3 of 5
Guru
I would try a full 30/30/30 reset. Thats push and hold reset for 30 seconds while powered up, then power it down for 30 seconds while still holding reset, and then power it back up for 30 seconds all while still holding reset. Should be holding reset it for  total of 90 seconds with all 3 steps.
Message 4 of 5
Guru
btw, you're posting in the AX router section of the forum. Not your fault as its a little confusing. Sometimes the moderators will move it but this is the normal forum for your router:
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 408 views
  • 0 kudos
  • 2 in conversation
Announcements
