Reply
R6400v2
mptaholland
Follower
R6400v2
I am trying to hardwire my router to my dvr(security cameras).  When I plug the Ethernet cable into extra LAN outlets, it lights up red.  What can I do connect?
Message 1 of 3
Guru
Re: R6400v2
Lights up red on what?
the router? Where on the router? what light?
On the dvr? where/what light? What do the instructions say about hardwiring in the system?
If you hook a computer to the router, does it work?
Current Setup: CM2000-> SXK30-> GS716v2-> RAXE500->
Message 2 of 3
schumaku
Guru
Re: R6400v2
Or is this "red" more "amber" or "orange" and does show on the LAN/Ethernet port where the DVR or it's camera(s) are plugged? That would indicate ...
Ethernet ports 1–4
The LED color indicates the speed: white for Gigabit Ethernet connections and amber for 100 Mbps or 10 Mbps Ethernet connections.
• Solid. A powered-on device is connected to the Ethernet port.
• Blinking. The port is sending or receiving traffic.
• Off. No device is connected to this Ethernet port.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 342 views
  • 0 kudos
  • 3 in conversation
Announcements
