× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RBR20 connected but not downloading
65ark
Tutor
Modem is working fine.
Orbit app:  Internet Speed test shows fast up/down speeds.  Internet is listed as "offline".  Network Map:  Router is pink, Satellite is green.
Rokus can connect to wifi and are working fine, but phones, tablets, & PCs can connect to the wifi network but cannot access the web.
any suggestions?
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 6
Accepted Solutions
Guru
Re: RBR20 connected but not downloading
What firmware are you on?
have you tried a simple factory reset/reinstall?
Message 4 of 6
All Replies
Guru
what actual modem do you have?
Message 2 of 6
65ark
Tutor
NETGEAR CM500
Model: CM500V|Cable Modem for Internet & Voice–DOCSIS 3.0
Message 3 of 6
Guru
Message 4 of 6
65ark
Tutor
the factory reset worked - thanks.
Message 5 of 6
Guru
glad to hear it!
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1376 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
