Reply
RBR50 - flashing & pulsing white light / no wifi / cannot factory reset / tftp flash no help
jjc23
Changed internet provider and after powering off my RBR50 and connecting to new cable modem it never recovered.
Symptoms - alternating between flashing and pulsing white light on router. Power LED green. No wifi signal being transmitted. Unable to connect directly to router via LAN.
Troubleshooting steps taken:
- Powered down and restarted
- Reset (tried various lengths holding down reset button) - resulting in power lights of either flashing red, solid green or amber
- Successfully uploaded firmware via TFTP client (per https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client)  - had to use the reset method of holding down reset untl power light flashed red several times, green once and then red before router would accept TFTP. Unfortunately, after FW put, router just went back to flashing / pulsing white
Router is 13 months old, so no warranty support. Based upon search the community forum there are no other steps I can find to take and it seems like it could be bricked.
Any other suggestions??
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 2
Accepted Solutions
Guru
Re: RBR50 - flashing & pulsing white light / no wifi / cannot factory reset / tftp flash no help
Might want to repost this in the Orbi section
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 902 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
