× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RBR50/
Ali-OB
RBR50/
RBR50v2
Can I buy an additional satellite to plug into this?
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 3
Accepted Solutions
Guru
Re: RBR50/
yes you can.
Compatible models are:
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Keep in mind, only the 50 series support the full 1733mpbs backhaul. The other series only use a 866mbps backhaul.
Message 2 of 3
All Replies
Guru
Re: RBR50/
yes you can.
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
Message 2 of 3
Ali-OB
Re: RBR50/
Many thanks for your reply. Most helpful.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1093 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
