- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RBS40V no aggiornamento firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have an Orbi RBR50 V2.5.2.4 Router with Orbi RBS40V V2.5.1.6.
The RBS40V cannot update the firmware
I also tried manually (with firmware https://www.downloads.netgear.com/files/GDC/RBS40V/RBS40V-V2.6.1.4_1.0.1.zip) but the problem is presented anyway
I also tried to reset the device to factory settings but without benefit
can you give me suggestions?
Thanks
Alessandro
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RBS40V no aggiornamento firmware
What actually happens or what error are you getting?
What process are you using? updating manaully? updating through the app? Updating on the satellite's login page?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
photos don't show until a moderator approves them
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry
the message: Firmware upgrade failed. Please check your file.
tank you
- Mark as New
- Bookmark
- Subscribe
- Permalink
there's 2 versions of the rbs40v. make sure you select the correct one from the drop down.
Also, make sure you extract the file.
also, there firmware for when its running in orbi mode and firmware for extender mode. Make sure you download the correct one for what mode you're using it in.
