- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rbr850 compared to Vilo
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rbr850 compared to Vilo
it looks like theres been quite a few reviews already on the Vilo.
https://www.reviewgeek.com/91143/vilo-mesh-wi-fi-system-review-super-affordable/
https://gizmodo.com/this-is-the-cheapest-way-to-get-good-mesh-wifi-in-your-1847248491
plus more.
does it work as a mesh? Yes
Is it going to be even close to the performance of the RBK850? Not even slightly.
will it be good enough? Depends on what its used for, size of the home, how your home is setsup, and your expectations. We don't know those or what you kids need based off the limited info you gave.
depending on what the situation is, other solutions might be better that vilo and cheaper than the Orbi setup all while keeping similar perfomance.
Is the home wired with ethernet? If so, then a cheaper dual band system could work.
If the home is small enough, a single router solution might be a better option.
