Reply
Readynas Ultra 4 Plus no valid volume exists
theali3n
I had a disk failiure on drive 3 which then rebuilt. Then I had a disk failure on drive 2 and my volumes are gone. I got another replacement, but something is not right and the array won't autobuild.
I noticed that when I saw the degrarded arround and volumes were not working I rebooted the array. Drive 3 seems to live and active, but it still can't see the old volume and won't rebuild.
I ran the following and got:
storage:/# mdadm --assemble --scan
mdadm: /dev/md/E091F58B67DA:2 assembled from 2 drives and 1 spare - not enough to start the array.
I have 4 2TB drives.
Live dmesg I see:
md/raid:md1: raid level 6 active with 4 out of 4 devices, algorithm 2
RAID conf printout:
--- level:6 rd:4 wd:4
disk 0, o:1, dev:sda2
disk 1, o:1, dev:sdd2
disk 2, o:1, dev:sdc2
disk 3, o:1, dev:sdb2
md1: detected capacity change from 0 to 1073610752
md1: unknown partition table
md: bind<sdd5>
md: bind<sdc5>
md: bind<sda5>
md: md2 stopped.
md: unbind<sda5>
md: export_rdev(sda5)
md: unbind<sdc5>
md: export_rdev(sdc5)
md: unbind<sdd5>
md: export_rdev(sdd5)
md: bind<sdd5>
md: bind<sdc5>
md: bind<sda5>
md: md2 stopped.
md: unbind<sda5>
md: unbind<sdc5>
md: unbind<sdd5>
I have not kicked off any new processes or anything, but I did slide the new drive in and it was checked and passed, but no rebuild or anything. I have years of data on there and I would like to try and get it back.
If anyone has any suggestions or would like any info to help suggest a few things please let me know. If anyone thinks I should STOP and contact Netgear support please let me know.
Model: RNDP400U (ReadyNAS Ultra 4 Plus)|READYNAS ULTRA 4 PLUS (DISKLESS)|EOL
Message 1 of 3
Re: Readynas Ultra 4 Plus no valid volume exists
Nothing to do with routers. (See section heading.)
You might get better and quicker replies, and find other answers, over in the appropriate section for your device:
ReadyNAS Network Storage: Official NETGEAR Community
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 3
theali3n
Agreed. My error. Thanks.
Message 3 of 3
Discussion stats
  • 2 replies
  • 298 views
  • 0 kudos
  • 2 in conversation
Announcements
