Reply
Recent update
Collen1948
Follower
Recent update
I hooked up my router 10/24/2018. Is their an update that I should download.  My provider said I should have an update every year.
Thank you, Cathy
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 1 of 2
Guru
Re: Recent update
what firmware are you on?
the most current version for the R6220 is 1.1.0.92.
You can manually download and install it over a hardwired connection. This is what I recomend for firmware updates as most errors happen from updates happening over a wireless connection or updating through the app.
Here's the support site. it has the firmware, manual, troubleshooting, and even videos of install/firmware updates.
https://www.netgear.com/support/product/R6220.aspx
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 307 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
