Reply
Regular high ping times to router
bocarat
WNDR3700v2, running 1.0.0.12, been in place for quite some time, no real issues as I reboot it on a timer every 3am.
Just recently I started getting VOIP issues that runs over our corporate VPN (I am remote). I tracked this down to errant ping times to the router. Minutes of <1ms, followed by 5 seconds of 2-400ms. This was over 2.4ghz.
I changed to 5ghz and it is better, but still seeing a jump to 40-100ms on a similar timeframe/schedule.
I looked into it this morning, and found pretty well all devices in the house other than my printer and phone and Sprint AirRave (booster) were disconnected. The AirRave has been in place for a year or more.
In the last week or so I have started adding a couple of Netgear gigabit switches to the network and added a couple of devices, but this shouldn't affect things in this manner - should it?
Suggestions on how to track this down? I don't see any barrage of messages in the router log.
What can cause these intermittent (but regular) high ping times?
Thx!
Message 1 of 8
Retired_Member
Not applicable
Re: Regular high ping times to router
Remove the switches and test.
I had 3 of those plastic white cases (POS) eight port netgear switches go bad.
Did they ever fix the AIRAVE? If your network went down the sprint phones stayed connected to the Airave and you had No service.
I canceled my service because of that. You cannot even make a 911, also you cannot stop others from using the 3g data if they are close to your home.
Message 2 of 8
bocarat
Hmmm. Good idea on the switches. They are 8 and 5 port blue metal case ones though. But still.
Without the airave I basically have no cell service anyway in the house. Would need to step away 100 yds. to get 1 bar and be out of it's range. No other houses in range.
Will let you know.
Message 3 of 8
Retired_Member
Not applicable
The blue switches in metal case have worked quite well. The reboot at 3am, is done via timer toggling power? The router may be failing. I would pickup another and see if problem goes away.
Is airave between modem and router or after router?
before replacing try factory defaults and re-entering configs
Message 4 of 8
bocarat
Yes, reboot is on a plugin timer, basically turns it off for an hour at 3am. Solved 99% of issues. Airave connects direct to the router using cat5e. How would you put it between modem and router.
Message 5 of 8
bocarat
I pulled the switches - no change....Smiley Surprised(
Message 6 of 8
Retired_Member
Not applicable
airave after router is how I used mine.
I would consider replacing the router if you tried a reset to default.
Message 7 of 8
bocarat
So I wrote some code to run a steady ping and pull the latency and stick in a database, then run a query to look for patterns. Time stamp is pretty close to the second, (just realized my code is slightly buggy if I get multiple pings >999ms in the same snapshot - currently 100 pings). But no worries as all below 200ms for now. So you can see it is usually every 3 minutes or thereabouts. WTH runs every 3 minutes!?!?!?!?
select * from Util.Ping
where latency >30
order by %id desc
8760 192.168.0.1 04/04/2014 14:09:42 45
8567 192.168.0.1 04/04/2014 14:06:47 101
8371 192.168.0.1 04/04/2014 14:03:48 102
8369 192.168.0.1 04/04/2014 14:03:47 109
8368 192.168.0.1 04/04/2014 14:03:46 91
8179 192.168.0.1 04/04/2014 14:00:55 55
7985 192.168.0.1 04/04/2014 13:57:59 85
7980 192.168.0.1 04/04/2014 13:57:55 69
7791 192.168.0.1 04/04/2014 13:55:02 106
7787 192.168.0.1 04/04/2014 13:54:59 94
7786 192.168.0.1 04/04/2014 13:54:58 126
7595 192.168.0.1 04/04/2014 13:52:05 98
7594 192.168.0.1 04/04/2014 13:52:04 81
7593 192.168.0.1 04/04/2014 13:52:03 52
7404 192.168.0.1 04/04/2014 13:49:12 36
7400 192.168.0.1 04/04/2014 13:49:09 47
7205 192.168.0.1 04/04/2014 13:46:12 97
7204 192.168.0.1 04/04/2014 13:46:11 84
7015 192.168.0.1 04/04/2014 13:43:19 94
7010 192.168.0.1 04/04/2014 13:43:15 56
6820 192.168.0.1 04/04/2014 13:40:23 102
6819 192.168.0.1 04/04/2014 13:40:22 76
6818 192.168.0.1 04/04/2014 13:40:21 51
6817 192.168.0.1 04/04/2014 13:40:20 33
6816 192.168.0.1 04/04/2014 13:40:19 53
6624 192.168.0.1 04/04/2014 13:37:24 104
6623 192.168.0.1 04/04/2014 13:37:23 85
6239 192.168.0.1 04/04/2014 13:31:35 142
6238 192.168.0.1 04/04/2014 13:31:34 61
6237 192.168.0.1 04/04/2014 13:31:33 42
6100 192.168.0.1 04/04/2014 13:29:29 58
6099 192.168.0.1 04/04/2014 13:29:28 39
5963 192.168.0.1 04/04/2014 13:27:25 151
5962 192.168.0.1 04/04/2014 13:27:24 72
5961 192.168.0.1 04/04/2014 13:27:23 53
5959 192.168.0.1 04/04/2014 13:27:21 103
5958 192.168.0.1 04/04/2014 13:27:20 73
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4473 views
  • 0 kudos
  • 2 in conversation
Announcements
