- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Remove custom firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Remove custom firmware
Your best bet?
Go to the forum with the type of firmware is loaded on it and check about how to remove their firmware to run stock firmware.
Or use the custom firmware. Sometimes its actually decent and works.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@SullyMan95 wrote:
I have tried to reset the router with it's button and flash the factory firmware with TFTP2.exe and it fails.
Very old school. Why faff around with third party software when Windows can do the job?
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
This also explains how to enable TFTP on a Windows PC.
TFTP isn't the easiest operation, so if you are forced to use it try a web search for videos that guide you through the process.
For example:
Different device, but the approach is the same.
The good news is that TFTP has rescued many a dead device.
