Reply
Router WNDR3700 max connections
bonus
I think I'm about to purchase the router WNDR3700, but I'm missing som data on it:
1. What is the maximum number of concurrent/simultaneous NAT/P2P connections/sessions it can have?
2. What is the maximum number of concurrent VPN passthrough connections?
Anybody that knows these details?
Message 1 of 34
jmizoguchi
Virtuoso
Re: Router WNDR3700 max connections
WRONG AREA
MOVING TO 3700 DISCUSSION AREA
VPN Passthrough = one session at at time
less than 100 is ideal but I seen around 200 do work on this 3700. Someone has already posted. if you raise the concurrent connection it will lock up the router so you will know when to quit. 99~300 something you can try
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 34
jerry66
Tutor
I' at 600 concur connections , no problem so far
Message 3 of 34
jmizoguchi
Virtuoso
nice... is that highest before lock ups?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 34
jerry66
Tutor
No , it is my standard setting , never tried more , never has locked up yet . So far this router is best for tors , it divides the bandwith evenly among 4-6 tors at a time . Other routers would have one tor suck all the bandwith leaving almost nothing for the other 5 , plus my top speed used to max out at 4.1-4.3 , now getting 4.9-5.2 Mbps top end .
Message 5 of 34
Mars Mug
Virtuoso
I think in another thread someone quoted a limit of something like 4096.
Message 6 of 34
Crusher88
Novice
4096???:eek::eek:
Message 7 of 34
Mars Mug
Virtuoso
That’s not particularly high, my router handles 15000 simultaneous connections and even that’s not exceptional.
I’m not convinced that with older Netgear routers the connection limit set in the firmware was the cause of failures, a limit of 100 was often needed to be set externally in the applications running on the LAN, but I suspect this was simply down to the processing power of the routers.
Here you go;
http://forum1.netgear.com/showthread.php?t=44959
Message 8 of 34
Crusher88
Novice
mars where can i find in the router configuration menu the way in order to see my current number of connections?
Message 9 of 34
jmizoguchi
Virtuoso
most users keeps trying until locks up..
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 10 of 34
Mars Mug
Virtuoso
I'm not aware that you can through the GUI, and I'm not at all familar with using telnet or suchlike. Sorry, not much help there.
Message 11 of 34
bonus
Mars Mug wrote:
Here you go;
Thanks!
It seems that Netgear is not so good in specifying this type of data. Mostly up to trial and error from users. Anybody that has seen any official data from Netgear?
Agree, even 4096 does not sound so impressing. Which router do you have?
Message 12 of 34
Mars Mug
Virtuoso
I have one of these;
http://www.draytek.co.uk/products/vigor2950.html
Which is really a business grade router, but I have heard of home grade routers that offer around 15000 connections or higher, you should not have to pay more for that feature. I suspect that with limited memory capacity if too much is allocated to this, then other features may suffer or not be included.
Message 13 of 34
beisser
you dont. there is no way to see them.
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the universe trying to produce bigger and better idiots. So far, the universe is winning." -- Rich Cook
Message 14 of 34
stephenstud
How do you chnge them?
Message 15 of 34
jmizoguchi
Virtuoso
you can NOT change is it.. 4096 max session for this router ...
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 16 of 34
stephenstud
Oh, so they are built in:) Ok, thank you:)
Message 17 of 34
jmizoguchi
Virtuoso
every router has it's own max session connection (concurrent connection value) and all are different in value which is limited by the firmware which is hard coded 🙂
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 18 of 34
stephenstud
Are you pretty happy with that?
Message 19 of 34
stephenstud
Im sorry I have hijacked this thread.... Do you recomend a router(business or home), that can handle a lot of connections that wont even blink?
Message 20 of 34
jmizoguchi
Virtuoso
Prosafe routers
See at Netgear.com and look prosafe router and look at spec tab. It will show the session value
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 21 of 34
stephenstud
jmizoguchi wrote:
Prosafe routers
They can handle alot? And I dont need any 3rd party firmware? That would be nice!
Message 22 of 34
jmizoguchi
Virtuoso
Prosafe is business class. Does not use crappy third party firmware
See the spec at site yourself
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 23 of 34
jmizoguchi
Virtuoso
http://www.netgear.com/business/products/security/wireless-VPN-firewalls/SRXN3205.aspx
Spec tab! Look at concurrent value
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 24 of 34
stephenstud
Thats the one I was looking at:) I dont mind spending the money if it can handle alot of p2p, and my server.
Message 25 of 34
Discussion stats
  • 33 replies
  • 16186 views
  • 0 kudos
  • 7 in conversation
Announcements
Orbi WiFi 6E
