- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router WNR2000v2 Slow Internet
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi everyone,
Hope you guys can help me! I have a Spectrum modem which provides 100mbps (tested already). However, I connect it (with an Ethernet cable) to my WNR2000v2 router and my internet goes down to 30mbps when I do the speed test in my laptop (connected to the router via wireless). I updated the router to the last firmware and also performed a factory reset, but nothing seems to help. Help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router WNR2000v2 Slow Internet
If you're wanting faster wireless, you need to update the router.
The WNR2000v2 is a N300 device. Meaning its a single band device that runs on 2.4ghz. 2.4ghz is slow and sensitive to interference. For areas with many wifi networks 30mbps over 2.4ghz is actually considered a good speed.
For faster speeds, you'd want to upgrade to a dual band router. 5ghz is significantly faster and less sensitive to interference. Only downsides to it is that it doesn't broadcast as far or through as much materials as 2.4ghz.
https://kb.netgear.com/29396/What-is-the-difference-between-2-4-GHz-and-5-GHz-wireless-frequencies
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I were you I'd upgrade to something newer, that will not give you the speeds you are paying for. Its a little old, you can still save it and use it as an access point but the newer routers can give you better output.
