Reply
Router Wifi + Password
pamalvarado
Follower
I am trying to reset my wifi and password for my router, however it is saying the log in info is incorrect. I previously changed the user name and password without issue, then the router had to reset and it went back to its original user name and password. neither the original usr name and password nor the one i previously set it to is apparently correct in efforts to change it again.
Message 1 of 2
antinode
Guru
Re: Router Wifi + Password
> I am trying to reset my wifi and password for my router, [...]
   What is your (unspecified) "my router"?
   Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation.  Get the User Manual.  Look for "Types of
logins".  Which user name and/or password are you trying to use to do
what, exactly?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 249 views
  • 0 kudos
  • 2 in conversation
Announcements
