Reply
Highlighted
Router doesn't recognize printer
The network map sometimes shows all connections and other times shows only computer and printer is noted to be "offline." Often when I reboot the modem, it will then find the printer. Don't know from day to day if the printer will print or not. Very confused.
Message 1 of 6
Highlighted
Virtuoso
Re: Router doesn't recognize printer
Are all devices with network map shows the same behavior?
Message 2 of 6
Highlighted
Yes. I have to reboot the router every day and then all devises are on map; otherwise it just shows one device.
Message 3 of 6
Highlighted
Virtuoso
If only one devices shows on the attached devices, are other devices still get an IP from the router and can go online?
Message 4 of 6
Highlighted
Don't understand your question.
Message 5 of 6
Highlighted
Virtuoso
If you can see only device shows on the attached device, have you tried checking other devices which is currently connected to the network but does not show on the attached devices if it has an IP address?
Message 6 of 6
Discussion stats
  • 5 replies
  • 4761 views
  • 0 kudos
  • 2 in conversation
Announcements
