Discussion stats
  • 1 reply
  • 1225 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Router doesn't show any lights except usb light
While updating the router my router suddenly blacked out. I don't see any power led light's nor do I see any Wifi or internet light, I only see the usb light. I tried to reset the router but then wifi and internet lights keeps blinking. Please help
Model: D3600|N600 WiFi Modem Router - 802.11n Dual Band Gigabit
Message 1 of 2
Highlighted
Master
Re: Router doesn't show any lights except usb light
Sounds like the firmware get screwed up and now the modem/router is not booting up you may need to reflash the unit with new firmware, if you are lucky you can access the router in any way via a wired lan port.
If you can not you will have to try a serial cable to access the modem/routers main board there may be a guide on youtube for the unit.
I guessing that you tried reseting the unit.
Have you tried a 30-30-30 reset it may help.
Message 2 of 2
