Reply
Router not seeing wired connections
82katana
Suddenly, my router is refusing to allow wired devices access to the network. The LEDs on both the router and the devices show a good connection. All of the wireless devices can see each other and the internet. Anyone have this problem? They were working yesterday and they are not working today. I didn't do anything to the router prior to the change. Since then I soft booted, hard booted and now I have done the firmware upgrade to the router. No luck. My next step would be to reset the to factory and start all the configuration again. I would rather not do that. Any suggestions?
Message 1 of 4
Marto731
Re: Router not seeing wired connections
Katana,
I need more info.
* Model no of Router?
* Any switch between Router and wired PC's?
If on a Windows machine: Start > Run > cmd.
Type "ipconfig".
Do you get a 192.168.xx.yy address for your PC?
If you are not getting an IP address, and eveything was working fine, until 2 days ago, then I would have to conclude that the device has a hardware fault, and you are looking at replacing.
Marto,
Netgear Tech Support 😛
NETGEAR ReadyNAS Former Employee-- Tech Support & Documentation
Contact Information: http://support.netgear.com/general/contact/default.aspx
Message 2 of 4
82katana
Model Number: WNDR 3800
Nothing between router and PC
Occasionally the router will show the wired connection in the attached devices list. When this happens, I get the same IP address when I do the IPCONFIG. However, I am still not able to connect to the internet AND I cannot ping the router.
I would hate to see this router is bad already. I just bought the darn thing 6 months ago.
Thanks for any help you can give
Message 3 of 4
sabretooth
Apprentice
Hard reset the router and reconfigure it.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3859 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
