× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Router speed
mbelaney
Follower
Router speed
how do i change my router to 5G setting?
Message 1 of 2
Guru
Re: Router speed
What router do you have?
If you have a dual band router and it doesn't have smart connect, then its usually the phone/tablet/device that you choose which to connect to.
But again, easier to know with model numbers.
You can also go to netgear.com/support/   and type in a model number. it takes you to manuals, guides, etc
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 499 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
