Reply
Router
Klucier
Follower
Router
I need to update the new firmware.  The directions tell me to connect my computer to the router with an ethernet cable.  It is wireless and I don't have an ethernet cable.  How do I do the update?
Model: WNDR3400v3|N600 Wireless Dual Band Router
Message 1 of 2
Guru
Re: Router
we usually recommend doing it over a hardwired connection. You can do it over wireless.
but we recommend it hardwired because if we see corrupt firmware issues, it tends to be done over wireless or through the app.
Options?
Make a backup and give it a try wireless.
buy a cheap usb----ethernet adapter so you can hardwire in
Or just not update
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 382 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
