× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
SSID Broadcast
prflip157
SSID Broadcast
SSID for 2Ghz stopped broadcasting.  I have restarted, turned off/on "Enable broadcast" and applied, but cannot see SSID as available wireless option.  Need this as many home devices cannot connect to 5Ghz.
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 8
Re: SSID Broadcast
What do the LEDs show?
Message 2 of 8
wcalifas
Prodigy
Re: SSID Broadcast
Is there a button on the outside of the gateway that let's you turn on or off the wifi? If so press it for 5 seconds and see if that changes it, if not press it for 10 seconds if it has that button.
Message 3 of 8
prflip157
Re: SSID Broadcast
There is a on off button at the back close to the coacts connection. I press that but that didn’t solve the issue.
Message 4 of 8
prflip157
Re: SSID Broadcast
All of the lights are lit.
Message 5 of 8
wcalifas
Prodigy
Re: SSID Broadcast
There should be a wifi button on off on top
Message 6 of 8
Re: SSID Broadcast
Be warned. The wifi button is actually an LED that doubles as a switch.
You would not be the first person to be baffled by that.
The bugger is that you need to enable the wifi in the browser graphical user interface and check that the switch is on. Disable in the GUI and the button is useless.
If a;; the switches are on, them there is another problem somewhere.
Message 7 of 8
prflip157
Re: SSID Broadcast
THANKS TO ALL WHO REPLIED!!
The “reset” button brought back the missing SSID broadcast...
Thanks again!!
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1001 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
