Reply
Security Question Fail
mdvierra
Follower
I type in 192.168.1.1 in my browser and use the following user/password:
admin
password
After three attempts it brings me to a security page. I answer the questions. I get the following response:
This site says...
The information you entered does not match what is saved on the router. Please enter it again.
I reset the router by pushing the button on the back of the device in until the lights went off and then came back on as before. I then attempted to login to the router via 192.168.1.1 / routerlogin.net and hit the same roadbloack.
Can anyone help me? The default user/pass according to the manual for my router is "admin" & "password"; after doing a physical hard reboot of the router I would assume it would let me in to the setup page but regardless of how I login via 192.168.1.1 or www.routerlogin.net I am taken to the same security question and none of my responses get me past that splash screen to the routers settings.
My router's information is:
R7900 — Nighthawk X6 AC3000 Tri Band WiFi Gigabit Router
Please, anyone with any information that can help would be greatly appreciated!
Model: R7900|Nighthawk X6 AC3000 Tri-Band WiFi Router
Message 1 of 2
Re: Security Question Fail
What modem, if any, sits in front of this router?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 426 views
  • 0 kudos
  • 2 in conversation
Announcements
