× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Security
Jumper13
Follower
Security
Can I change my security setting from WEP to WPA2-PSK {AES} on my WNR2000v5?
Message 1 of 4
Accepted Solutions
antinode
Guru
Re: Security
> WNR2000v5?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Specify Basic WiFi
Settings" and "Change the WiFi Security Option".  I see:
      5. Under Security Options, select a WPA option:
         o WPA2-PSK [AES]
         o WPA-PSK [TKIP] + WPA2-PSK [AES]
         o WPA/WPA2 Enterprise
> Yes, if the router and all clients support it.
   Well, duh.
Message 3 of 4
All Replies
TaterSalid
Virtuoso
Re: Security
Message 2 of 4
antinode
Guru
Re: Security
> WNR2000v5?
         o WPA2-PSK [AES]
   Well, duh.
Message 3 of 4
TaterSalid
Virtuoso
Re: Security
   Well, duh.
Researching from a phone is difficult! But hey, why don't you go ahead and do the research for the clients too.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1067 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
