Reply
Setting date
ggrussell
Setting date
I noticed the the date displayed for files on my USB shared storage says 2011. Where do we set the date in the router. I've checked everything and searched the manual PDF and can't find anything.
TIA
Message 1 of 3
sabretooth
Apprentice
Re: Setting date
You can't. You can only set the time zone as the router picks up the NTP server for the date and time.
Message 2 of 3
jmizoguchi
Virtuoso
Re: Setting date
TIA
All the dates stamps based on current time is what router has. You may have had correct dates while sometime it will looses the sync to NTP servers where it will default to totally different dates.
If you go to your time zone and you have already and/or selected correct time zone while current dates is not correct then power off and on the router but 10 sec wait and see if it will re sync with NTP server hard coded in the router's firmware,
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2344 views
  • 0 kudos
  • 3 in conversation
Announcements
