× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Slow internet speed issue with NETGEAR N600
Sukhjeevan
Hi All
I have NETGEAR N600 Cable Modem Router (C3700). My internet speed is only around 40 Mbps even I do have 200 Mbps xfnility internet plan. xfinity support asked me to contact Wi-Fi device manufacture company. Any suggestion what can I do to get expected speed.
https://www.amazon.com/gp/product/B00IF0JAYE
Thank you
Model: C3700|N600 Cable Gateway Docsis 3.0
Message 1 of 3
antinode
Guru
Re: Slow internet speed issue with NETGEAR N600
> [...] My internet speed is only around 40 Mbps [...]
   Measured how?  Using what for a client device, connected how?  Wired?
Wireless, 5GHz? Wireless, 2.4GHz?
> [...] what can I do to get expected speed.
   What is your "expected speed"?
   Why blame the C3700 rather than your (unspecified) client device?
Does your (unspecified) client device get higher speeds in some other
environment?
Message 2 of 3
Sukhjeevan
I'm using HP laptop Elitebook and connected internet via Wi-Fi connection.
Tested with Network Band at 2.4 GHz
  • Disconnect from office VPN
    • xfinity speed test: ~50 Mbps
    • speedtest.net speed test: ~10 Mbps
  • Connect from office VPN
    • xfinity speed test: 0 Mbps
Tested with Network Band at 5 GHz
    • xfinity speed test: ~120 Mbps
    • speedtest.net speed test: ~20 Mbps
    • xfinity speed test: ~0 Mbps
Speed is little better now with 5 GHz but only while disconnected from office VPN. I cannot work while disconnected from office VPN so not much helpful.
In office I get enough speed and don't see any disturbance while attending online meetings.
Is there any other setting I can change in modem router to get higher speed? If not any suggestion for good modem router.
Thank you
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 920 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
