Discussion stats
  • 1 reply
  • 2298 views
  • 1 kudo
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
So Far I Love My R6250 AC1600
I just bought one used (cheap) a week ago and it's working great! 1st thing I did was update the firmware then set it up. I'm not using the 2.4ghz band, just the 5ghz is enabled since all my devices have AC WiFi. I'm getting full speeds on my devices and the range is great. It's by far the best router I have even owned. All my previous routers were D-Link and all were good accept the DIR-862 AC1600 that I had to return to the store because the 5ghz radio didn't work. I also love the way it looks.
Message 1 of 2
Highlighted
NETGEAR Employee Retired
Re: So Far I Love My R6250 AC1600
Thanks for the post; it’s very rare to find someone posting praise without an issue or question, if you do run into any problems or want some general advice, this is a good place to come to.
____________________________
Working on behalf of Netgear
My name is Andy
Message 2 of 2
