× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
The network you are using may require you to visit its login page
Girma
Follower
I'm getting a page with "Connect to Network: the network you are using may require you to visit its login page" whenever I search or type in a URL on chrome. The same issue is happening on edge too. There's a yellow triangle with a black exclamation mark showing there's no internet in the bottom right corner of the screen. When I hit the connect button on the webpage it just takes me to the login for routerlogin.net
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 1 of 3
Accepted Solutions
DexterJB
NETGEAR Moderator
Re: The network you are using may require you to visit its login page
Hi @Girma,
Please make sure you have through the process of configuring the router. The links below may help out.
http://kb.netgear.com/app/answers/detail/a_id/22697
http://kb.netgear.com/app/answers/detail/a_id/22717
The installation guide on the user manual linked below may also help out.
http://www.downloads.netgear.com/files/GDC/R6220/202-11443-04_R6220_EN_08Jan2016.pdf
Dexter
Community Team
Message 2 of 3
All Replies
DexterJB
NETGEAR Moderator
Hi @Girma,
Dexter
Community Team
Message 2 of 3
DexterJB
NETGEAR Moderator
Hi @Girma,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 78605 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
