Jflow's avatar
Jflow
Follower
Aug 04, 2021
Two wifi networks in one house
I have an ATT 5286AC Router/Modem.  Can I set up the Orbi RBR750 and a completely new second Wifi network along side the ATT Wifi network?
  • plemans's avatar
    You can.
    A couple things though.
    1. make sure you either put the netgears IP address into the ATT's DMZ or put the netgear into access point mode. that'll prevent a double nat
    2. Make sure to seperate the wireless channels to prevent interference.
    • antinode's avatar
      antinode
      Guru
      > [...] Can I set up the Orbi RBR750 and a completely new second Wifi
         Why?  Is there some actual problem which you are trying to solve?
         Are you looking for broader wireless coverage, or some kind of
      separation between your two "Wifi networks", or what?
         Do you want client devices on one "Wifi network" to be able to
      communicate with client devices on the other "Wifi network"?
      > [...] or put the netgear into access point mode. [...]
         That should give you one extended LAN where every device could
      communicate with any other.  But it would disable any fancy router
      functions on the RBR750.
            https://kb.netgear.com/26765
