Reply
UPnP Bug ?
zipperx
UPnP Bug ?
Rebooted my pc and after logging in and starting everything up i happened to look in my Network Connections properties and noticed the Internet Gateway with the upnp services was missing. It was there before i rebooted
Then i went into the upnp setting in the router and there were no upnp services listed either, yet upnp is enabled (enabled by default). So then i re-enabled the setting and it all came good. The services were showing and the Gateway came back
Anyone else had this happen ? Firmware bug or glitch ?
Firmware: 1.0.0.18
Message 1 of 2
jmizoguchi
Virtuoso
Re: UPnP Bug ?
bug report at my.netgear.com
forum is user to user only so you will need to documents with support
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2036 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
