Reply
USB connection issue on WNDR3700 router
ddrasko
Novice
Hi guys, here is my problem.
I have external Hard drive connected on USB port on WNDR3700 router. It worked just fine but today when I turned drive on, simply stopped. At first I was thinking that my Hard drive died, but is actually working fine when I plug it in laptop directly. I tested few flash drives and router simple does not see them!? Obviously, USB connection on router is not working. How to fix this? Is there a cure for this problem?
Thank you in advance,
Message 1 of 3
ddrasko
Novice
Re: USB connection issue on WNDR3700 router
I found the solution. Just power router Off and wait 10-30 sec and power back ON. That will "reset" and wake up USB port.
I am very surprised that NOBODY post any answer regarding this thread!?
Message 2 of 3
scruffeone
I tried this and didn't work. I have a Toshiba Model HDDR250E02X USB drive and it worked for all of about 2 days, then the USB light went out on the router and It hasn't come back on at all. I turned off the router, no help. Everything else seems to work fine. :confused:
Message 3 of 3
Discussion stats
  • 2 replies
  • 5680 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
