Discussion stats
  • 4 replies
  • 3427 views
  • 2 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Unsecured Wi-FI Connection warning
This week, I suddenly started getting an "Unsecured Wi-Fi Connection" warning (from Trend Micro Maximum Security) on my Samsung Galaxy Note 9. When I opened Chrome (on my PC) and went to the IP address for my router, it did a firmware update but I'm still getting the not secure warning on my phone. Full warning message:
Using banking or shopping apps while connect to (network name) could put your personal data at risk. Switch to a different Wi-Fi network or use a 3G/4G connection instead.
Switch Networks
Close
  1. Why am I suddenly getting this warning?
  2. What do I need to do (if anything)?
I'm using:
  • NETGEAR WNR-2000v2
  • WEP128
  • WEP Key 26 numbers and letters
  • Firmware (updated today but can't figure out what version it is)
  • Chrome v. 74.0.3729.108 (Official Build) (64-bit)
  • Windows 10 Home 64-bit
  • Samsung Galaxy Note 9 with Android 9 (all updates installed)
  • Trend Micro Maximum Security (on both PC and phone)
Thanks for any assistance you can provide!
Model: WNR2000v2|Wireless-N 300 Router WNR2000v2|EOL
Message 1 of 5
Accepted Solutions
Highlighted
Sensei
Re: Unsecured Wi-FI Connection warning
> [...] I suddenly started getting an "Unsecured Wi-Fi Connection"
> warning (from Trend Micro Maximum Security) [...]
   Ask Trend Micro?
>    o WEP128
   WEP has been vulnerable/obsolete for some years, now.  Perhaps "Trend
Micro Maximum Security" now classifies it as "Unsecured".
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Changing Wireless
Security Settings".  Select something with "WPA" in it.  I'd probably
choose "WPA2-PSK [AES]".
   Then run around to all your wireless client devices, and reconfigure
them to use the new scheme.  To avoid confusion, it might make some
sense to specify a new/different SSID ("wireless network name") when you
change the encryption scheme from WEP to WPA[2].  Then you'd simply be
adding a new wireless network on each client device.
> o Firmware (updated today but can't figure out what version it is)
   On a less obsolete router model, it's normally displayed on almost
every page you'd get from its management web site ("routerlogin.net", or
whatever).  On your antique, it seems to be under Maintenance > Router
Status.  Look for "firmware" in the User Manual.
Message 2 of 5
All Replies
Highlighted
Sensei
   Ask Trend Micro?
>    o WEP128
Message 2 of 5
Highlighted
Thanks antinode! A couple more questions:
  1. Do you recommend that I get a new router?
  2. If so, any recommendations?
Model: WNR2000|Wireless-N Router
Message 3 of 5
Highlighted
Sensei
   Not if your antique does the job.  A newer model would likely have
more features, and be capable of higher wireless-network speeds, but I
know nothing about your Internet service or your client devices, which
means that I don't know where your bottleneck is now, so I can't
guarantee that a newer/faster router would make any noticable change.
   Nope.  Depends on your environment/requirements.  I'd definitely look
beyond Netgear, however.
Message 4 of 5
Highlighted
Thanks so much antinode!
Message 5 of 5
