Reply
Up to 300 Mbps?
Tal
Up to 300 Mbps?
Yeah I have a WNDR3400v2 and I saw no where else to post this so I ask here.
I have it set "Up to 300 Mbps" But InSSIDer only shows Max Rate of 144 Mbps, it will display 300 Mbps right after I set it and apply settings, but change back to 144? Why.
Message 1 of 7
sabretooth
Apprentice
Re: Up to 300 Mbps?
How many other AP's are around your channel from inSSIDer? It will throttle back even with one to reduce interference. Wouldn't worry about it.
Message 2 of 7
jmizoguchi
Virtuoso
Re: Up to 300 Mbps?
144Mbps means you are likely to be connected on 20Mhz instead of 40Mhz
http://en.wikipedia.org/wiki/802.11n
I would check if your wireless adapter support both 20/40Mhz.
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 3 of 7
Tal
Re: Up to 300 Mbps?
Okay thought so. What about teh 5GHz band? Do you know what channel I should set it to? My laptop can connect to the lower 40Mhz end but when I set it to 161 It won't at all.
Message 4 of 7
Tal
Re: Up to 300 Mbps?
Message 5 of 7
sabretooth
Apprentice
Re: Up to 300 Mbps?
Try ALL the channels to see which one works for you.
Message 6 of 7
jmizoguchi
Virtuoso
Re: Up to 300 Mbps?
usually 5Ghz has broad channel and router will find the best channel without conflict over 2.4Ghz that has only 13 channel with only 1,6,11,13 useable channel
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 5456 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
