Reply
dssilic
Update
I have never been able to update my router software (currently V1.1.00.30).  The error message is "Update failed".
I also can not get an "Advance" menu in my Genie software, which the documentation says leads to an alternative way to update.  The "Genie" does not show it.
Any ideas of how I can do both?
Model: D6200|Dual Band 11ac ADSL Modem Router
Message 1 of 6
Guru
Re: Update
You can manually update the firmware.
How do I manually update the firmware on my NETGEAR router? | Answer | NETGEAR Support
CM2000-> RAX200-> GS716v2-> EX8000
Message 2 of 6
dssilic
Re: Update
A manual update requires going into the "Advanced" menu, which I can not do.
Message 3 of 6
Guru
Re: Update
Are you logging in through the browser?
Message 4 of 6
dssilic
Re: Update
Yes.  With Windows 7 Pro and Google Chrome.
Message 5 of 6
Guru
Re: Update
try using firefox and/or edge
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 133 views
  • 0 kudos
  • 2 in conversation
Announcements
