× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Upgrade to V1.0.1.12_1.0.58 broke 2.4Gz
ylb
The upgrade to firmware version V1.0.1.12_1.0.58 has halted functionality of the 2.4GHz spectrum on my router.  I've rebooted the router, stopped/started 2.4GHz SSID, reset the password for 2.4GHz, manually configured the channel from auto to multiple settings, and rebooted the devices attempting to connect to 2.4GHz.  I can see the 2.4GHz SSID being broadcast, however when I attempt to connect I recieve the generic message "Unable to join [SSID] network" after ~15 seconds from entering the password.
This is the same behavior for multiple devices on the 2.4GHz spectrum.  The 5.0GHz SSID works just fine for the same devices.
2.4 GHz Settings:
Enable Wireless Isloation: No
Enable SSID Broadcast: Yes
Channel: Auto
Mode: Up to 145mbps
Security Option:  WPA2-PSK [AES]
5.0GHz Settings
Channel: 153
Mode: Up to 300mbps
Any idea other than a firmware downgrade?
Model: WNDR3400v3|N600 Wireless Dual Band Router
Message 1 of 2
Accepted Solutions
ylb
Re: Upgrade to V1.0.1.12_1.0.58 broke 2.4Gz
I found a solution, but this should be logged as a bug for firmware version V1.0.1.12_1.0.58.
The Guest network for the 2.4GHz must be enabled for the non-guest 2.4GHz network to accept connections after upgrading to this version of firmware.
There is no reason why the guest network should be required to be enabled, but funtionally it is required in this version of firmware.
-ylb
Message 2 of 2
All Replies
ylb
-ylb
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 617 views
  • 0 kudos
  • 1 in conversation
Announcements
Orbi WiFi 7
