Reply
Use 5GHz bandwidth on 2.4GHz?
cclloyd
A lot of devices in our house are outdated and don't have 5GHz capability, making for a lot of networking through the 2.4 band. This can inevitally cause lag in the system.
So what I ask is if there is a way to give more than 450mbps to the 2.4GHz band, or a way to have certain 2.4GHz devices use the bandwidth of the 5GHz band.
Message 1 of 4
sabretooth
Apprentice
Re: Use 5GHz bandwidth on 2.4GHz?
Sure just buy a universal WiFi adapter that will do both, WNCE3001 will work. Also you can upgrade your computer adapters to 5Ghz dual band also.
Message 2 of 4
fordem
Mentor
Not unless you can replace the wifi cards in the affected devices with 5GHz ones.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Message 3 of 4
jmizoguchi
Virtuoso
You can simply disable the 5Ghz if you are not going to use it. There is not option to have priority over either of bands that if if you are using both band in mix mode.
450Mbps will only work if you have correct wifi adapter. Usually in form of USB wireless adapter for desktop, in laptop you may able to replace mini-PCI WiFi card
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3008 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
