Reply
Using 2 WNR1000
Quadzilla724
Follower
Using 2 WNR1000
I have two WNR1000 and I'm trying to set up a network that others can connect remotely. So I have two issues. I know nothing about networking, but can change settings in the admin web interface.
The reason I say I have two is I have two wired computers that are nowhere near the current router (the other is in the box). I'd like to use the second as a relay or bridge (if possible) for the wired computers away from the main router.
I'm using Mac OS X 10.4, 10.5 and 10.6.
Thanks for any dialog that will help walk me through this...or tell me it's not possible.
Message 1 of 2
jmizoguchi
Virtuoso
Re: Using 2 WNR1000
I don't think wnr1000 has WDS (wireless distribution system) in the router interface.
if you don't see then answer is NO. BOTH have to have WDS do wireless repeat ...
you will need like WN2000RPT instead if does not have WDS ...
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3597 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
