Reply
Using a USB3 drive as a NAS
ENGLISHREBEL
I have just had U-Verse installed which has 80211ac so my MacBook Air can connect at around 0.8 Gbps.  I have a Toshiba 1TB external drive that I use for back up but would like to attach this to my network as a NAS.  I need a device that has a Gigabit Ethernet port as well as a powered USB3 port.
Does Netgear make such a device?
Thanks
Alan
Message 1 of 8
nhann
NETGEAR Employee Retired
Re: Using a USB3 drive as a NAS
Hi @ENGLISHREBEL,
Yes, please see the NETGEAR product page for routers. There, you can run comparisons between the products to see which fits your requirements. Many of the routers listed do have Gigabit Ethernet and USB 3.0
http://www.netgear.com/home/products/networking/wifi-routers/
Message 2 of 8
ENGLISHREBEL
As I already have 80211ac router I am lookimng for the least expensive that has Gigait Ethernet and USB3,  Without having to sort through all of them could you please point me to a couple that meet my needs
Message 3 of 8
nhann
Hi @ENGLISHREBEL,
Not sure what is considered expensive for you.
You can simply checkmark the "Add to compare" for several of the router options below R7000 then click on "View Comparison" or use the filtering options on the left-hand side.
For range extenders, only the EX7000 and EX6200 have USB 3.0
Message 4 of 8
ENGLISHREBEL
Well I'm looking to spend around $30.  Do you offer a 80211n router with USB3?  I don't need high speed as my at&t gateway has 80211ac.  All I need is something to allow me to plug a USB3 drive into my network
Alan
Message 5 of 8
nhann
Hi @ENGLISHREBEL,
I don't believe you will find a N router with USB3.0 within that price range. USB3.0 is included in more recent router/extender models.
Message 6 of 8
ENGLISHREBEL
Not sure what an extender does but would allow me to connect my drive to the network?
Thanks
Alan
Message 7 of 8
nhann
Hi Englishrebel,
http://kb.netgear.com/app/answers/detail/a_id/24801/~/what-is-a-wireless-extender%3F
Information can be found on the official webpage that was linked previously.
For example: EX6200 -
http://www.netgear.com/home/products/networking/wifi-range-extenders/EX6200.aspx#tab-features
"READYSHARE® USB - Wirelessly share & access USB storage connected to the USB 3.0 port."
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2601 views
  • 0 kudos
  • 2 in conversation
Announcements
