Reply
WGR612 portforwarding problems! please help, urgent!
Crypt3r
ohai there, name is Crypt3r and new here 😛 mainly signed up to ask this question that might be so easy to solve, but here goes!
So i'm trying to open ports on my WGR612 router, i go to the "Port Forwarding"
and enter the port and the ip address "192.168.1.2" which is my ipv4/lan address, and then enter both TCP/UDP, and saving it, then i go to canyouseeme.org and check if i have that port open, but it turns out i haven't,
and i have tried using a static IP and i'm still using that, and NAT is open, but could it have something to do with that the internet cable first goes into a VoIP box, and there after into the router?
Thank You in advance
Crypt3r
Message 1 of 4
Mars Mug
Virtuoso
Re: WGR612 portforwarding problems! please help, urgent!
Does the router show a Public IP address or a Private IP address in the ‘Router Status’ page;
http://en.wikipedia.org/wiki/Private_network
Do you have details (manufacturer / model number) for the VoIP box?
What kind of modem or Internet connection do you have?
Is your Netgear router actually a WGR614?
Message 2 of 4
Crypt3r
Hardware Version WGR612V1
Firmware Version V1.0.1.4_1.0.2NA
Internet Port
MAC Address C0:3F:0E:8E:XX:XX
IP Address 192.168.115.XXX
Internet Static IP
IP Subnet Mask 255.255.255.0
Domain Name Server 213.80.XX.XXX
213.80.XXX.XX
LAN Port
IP Address 192.168.1.1
DHCP ON
that's what it shows, as for the VoIP box it's:
Manufacturer: Linksys
Model Number: SPA2102
Message 3 of 4
Mars Mug
Virtuoso
The 192.168.115.xxx IP address is a Private IP address, this means that the Linksys box is doing some Network Address Translation. This link suggests that it is also a router;
http://www.cisco.com/en/US/products/ps10026/index.html
And so you have some options, the easiest might be to configure the Netgear router as an access point e.g. http://support.netgear.com/app/answers/detail/a_id/965
Message 4 of 4
Discussion stats
  • 3 replies
  • 4707 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
