Reply
WGR614v10 Drops internet connection
TuckerB12
My WGR614v10 had been working fine up until yesterday, it now drops connection to the internet every couple hours and needs to be turned off and back on for it to work again. I don't think it idles out because this happens when I'm streaming videos and playing online games.Thinking it might be the cable modem I connected straight to the PC and it works fine when the router drops out, so its not the modem.. Any suggestions?
Message 1 of 6
jmizoguchi
Virtuoso
Re: WGR614v10 Drops internet connection
hard reset the router first
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 6
TuckerB12
I tried that and it worked for a day and just a couple minutes ago I lost connection again, any suggestions?
-Thanks
Message 3 of 6
jmizoguchi
Virtuoso
both wired and wireless?
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 4 of 6
TuckerB12
yes, I have two PCs connected to it one wireless and one wired, they both drop the connection at the same time.
Message 5 of 6
jmizoguchi
Virtuoso
if only happens when you streams then your bandwidth is small which may causing the issues
VPN Case Study
VPNCASESTUDY.COM
June Mizoguchi-
Message 6 of 6
Discussion stats
  • 5 replies
  • 3072 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
