Reply
WGR614v10 ip Problems
Superbee68104
Follower
I bought this Router wireless for the Wii i have always wired everything
BUT now today i would like to run wireless to my Tivo and a Computer
I got the Tivo wireless adapter gives me an error that it can't setup an ip address, also having the same problem trying to setup a Computer Wireless using a Netgear Wireless-n 150 USB Adapter
Any Help?
Message 1 of 3
Reckl3ss
Re: WGR614v10 ip Problems
try to powercycle the router first. if they still unable to obtain an ip address, check the wireless settings of your router (by going to www.routerlogin.com, username is 'admin' and the default password is 'password'), then check if you are typing the right settings/security key.
Message 2 of 3
Joe_
Apprentice
Question: Did you ever set up your router by following the installation guide that came with it? When you use the computer with the USB adapter, does your network's name (SSID) show up?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 4449 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
