Reply
WGR614v10 needs to be reset when traffic gets heavy
pagrubel
Follower
My WGR614v10 needs to be reset frequently. /we used to have to unplug it but i found out if I do a release then renew after logging into the router that works. I can actually do this and continue downloading large files. However, I don't want to have to do this.
We have wireless which is used by two laptops, some ipods and it is directly wired to two desktops. One has ubuntu 10.04 and the other Windows XP.
Is there something i need to do so this will stop happening. Today, it happened when my husband was the only one using one of the laptops so there wasn't much going on.
thanks,
tm
Message 1 of 2
jmizoguchi
Virtuoso
Re: WGR614v10 needs to be reset when traffic gets heavy
see router setup on my sig below and see if broadband and router is setup correctly
VPN Case Study
VPNCASESTUDY.COM
"Our Second To None VPN Related Setup Case Study[/COLOR][/URL]
"One Stop Solution To Your Netgear VPN Connectivity"
*Visit the site for Non-VPN related Doc & Links* [Windows & Mac user/support]
June Mizoguchi-
Message 2 of 2
Discussion stats
  • 1 reply
  • 4489 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
